Leaking liquid propane
Hello we're experiencing liquid propane leaking from the air filter housing when we turn off the ignition key off. Also getting a error code E38 on this fork truck. It's an Mitsubishi, Model # FBC30K
I'm leaning towards a regulator/vaporizer?
  • Posted 5 Feb 2021 04:11
  • By Pete_Farmer
  • joined 5 Feb'21 - 4 messages
  • Tennessee, United States
If you follow the propane hose from the tank to the forklift it will eventually tie into a 6" diameter round silver filter. The filter usually has a union fitting that connects it to the vaporizor. Those are the two items I'm referring to.
  • Posted 6 Feb 2021 23:40
  • By duodeluxe
  • United States
duodeluxe
I'm not very familiar with the parts you're asking about in reference. I'm very green in the troubleshooting of LP vehicles. Sorry
  • Posted 5 Feb 2021 11:59
  • By Pete_Farmer
Pete Farmer
Does it have an Impco system with the VFF30 lock/off filter. If so, I would replace both the lock off and the vaporizor.
  • Posted 5 Feb 2021 10:37
  • By duodeluxe
  • United States
duodeluxe
You're correct, I copied the wrong information off the list of forklifts. It is an FGC25N model lift.
So you don't think it's a regulator/vaporizer with the liquid pouring out through the air filter?
  • Posted 5 Feb 2021 10:14
  • By Pete_Farmer
Pete Farmer
It is most likely a model FGC30K. An FBC is an electric truck.
It sounds like you need a new LPG lockoff or solenoid.
  • Posted 5 Feb 2021 09:38
  • By duodeluxe
  • United States
duodeluxe
