Leaking Head Leaking
I changed the oil again in my old Clark, and it was milky. It is a 4 cylinder, but not the flat head. It is a C500 Y 50 model, and serial number Y3552673616. I think it was manufactured in 1977.
Can I still get parts for this thing? Who made this engine?
Any guidance is welcome!
  • Posted 5 Jan 2019 05:54
  • By CIC2016
  • joined 5 Jan'19 - 5 messages
There is a breather on the valve cover. You can tap the hole for pipe thread and install a PCV valve. This will stop allot of the condensation from building up in the crankcase. Your engine is a Waukesha.
  • Posted 9 Jan 2019 02:14
  • Modified 9 Jan 2019 02:15 by poster
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Possibilities, Waukesha diesel or gas or ford diesel or gas. I have manuals on both.
  • Posted 9 Jan 2019 01:32
  • By tom_p
  • Alberta, Canada
That's exactly whats happening. It does not leak out any coolant, so I suspect it is the condensation you describe. Anything else I can do to help minimize that?
  • Posted 6 Jan 2019 00:39
  • By CIC2016
I think that should be a Waukesha D155 motor. They had problems with lots of condensation forming in the crankcase and turning the oil milky. If it runs ok then there may not be anything wrong with the head/gasket. You should be able to get parts.
  • Posted 5 Jan 2019 06:23
Tanzania takes delivery of electric reach stacker Dar es Salaam, Tanzania, United Republic Of
June 23-25, 2026 - Melbourne, Australia
September 15-17, 2026 - SÃO PAULO, Brazil
September 16-17, 2026 - Dallas, United States
The charge carried by a bolt of lightning is so intense that it has a temperature of 30,000-degrees C (54,000-degrees F), five times hotter than the surface of the sun which is about 5,500-degrees C (10,000-degrees F).
