LCD screen not working
Can i swap the dash display from another truck? The light for the screen is on but no infomation showing. Never had one these go down on us before.
Serial no. prefix L177B
  • Posted 16 Dec 2021 00:39
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Luke
Thanks for the info chaps.
  • Posted 31 Dec 2021 07:40
  • By luke_m
Luke
Luke,
You only have a about 5 wires connecting to the display. I would take the connector apart and look at each wire to make sure you do not have any loose strands shorting against another wire. Check your wire harness where it goes down through the steer column. Make sure nothing is frayed. Good Luck.
  • Posted 31 Dec 2021 07:08
  • By Fishmech
  • Virginia, United States
I read your problem you could take dash out of truck and have it repaired at a company called flight systems after repair they will install new prom when you install back in truck VCm will re
Write to dash hope this helps
  • By Scott_
  • joined 16 May'21 - 347 messages
Scott
Thanks for your reply fish.
We swapped screen from another truck and that also blew. Expensive mistake.
We had the local hyster tech plug it in but he didn't really know what he was at fault, he was unsure if the screens were interchangeable and also if it was a fault with the vsm. Any help appreciated.
  • Posted 31 Dec 2021 06:43
  • By luke_m
Luke
Luke,
You can swap the display, but you have to move the Vehicle System Manager at the same time as they are linked by serial number of the lift. Installing another dash will show a serial number mismatch. Better to have a qualified tech to repair.
  • Posted 31 Dec 2021 06:24
  • By Fishmech
You can try it for nothing but Im sure you'll need it resetting back to factory by a Hyster tech.
  • Posted 16 Dec 2021 04:13
  • By andrew_k
  • joined 17 Mar'07 - 365 messages
  • England, United Kingdom
UN Forklift FD30-35T
UN Forklift FGL35T
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
