Lancer boss reach truck WR16
Error code A08--can anyone shed any light on this intermittant fault code please.
  • Posted 9 Feb 2011 08:32
  • By gary_f
  • joined 8 Aug'09 - 57 messages
  • Malaga, Spain
Thanks for help people. truck now repaired, i had a burnt out accell unit, a burnt out indicator unit and a faulty bosch controller, all working now but steering motor doesnt switch off via seat switch-puzzler is what caused the fault in the first place, there are no earth faults on the truck-any ideas?
  • Posted 29 Oct 2011 00:55
  • By gary_f
  • Malaga, Spain
Thanks for info, i can only see one cap, near the steinbock controller, this truck doesnt have a separate hydraulic module. Are there other capacitors, if so where are they located.Thanks for your help.
  • Posted 15 Oct 2011 18:51
  • By gary_f
  • Malaga, Spain
Hi Gary
check the capacitors on the truck sounds like youve got a blown one, which would give you higher voltage and make hydraulics run. probably the caps near the hydraulic module
  • Posted 15 Oct 2011 05:54
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
Truck went dead for customer, nothing works. no display on bdi, sent steinbock controller for repair, refitted, steering and hydraulics now work although power steering permanently on. No traction and the bdi doesnt work, checked supplys to bdi, all correct.have noticed i have 60v at the two traction terminals of the controller?? truck is 48v, sent controller back to repairers but they have tested it and say on the bench, everything works,including the bdi. Any ideas.
  • Posted 15 Oct 2011 04:52
  • By gary_f
  • Malaga, Spain
Hi Gary
What problems do you have with the truck?
  • Posted 15 Oct 2011 03:50
  • By powerlifter
Hi powerlifter, ive got problems with this lancer boss wr16 reach truck again, it has a steinbock controller, would you have a wiring diagram or any info on this truck. Regards. Gary.
  • Posted 15 Oct 2011 01:47
  • By gary_f
  • Malaga, Spain
Hi Gary
If the fault is intermittant it looks like you have a problem with the shunt wires try taking them off and cleanining make sure you put them back on the same way as you took them off if problem still there you will have to go into the box and trace the shunt wires to the pins and clean and make sure they have a good contact the shunt wires will be on a copper strip and the colours are purple and grey fasten by two philip screws.
Hope this helps let me know how you get on
  • Posted 15 Feb 2011 02:55
  • By powerlifter
A good engineer is a helpful engineer
Kai von Berg Kai von Berg
