Komatsu FB 30H-1E : lift error
Hello to anyone who can help. A malfunction of the forklift is not good working lifting ( forklift is able to drive ). DC Pump motor is controlled by thyristors... after pulling a lever for LIFT ( turning a lift switch on and moving with a potentiometer ) motor goes to the maximum power - no reaction to position of potentiometer, no change of the speed. "Electronic box" consists from : 1. CPU BOARD 2. PUMP DELAY/OVER SPEED/LIMIT MODULE 3. P500 PUMP LOGIC MODULE + 3 thyristors, 1 diode. Could you give me any information ? What I should focus to ? 1 ? 2? 3? Could you send me any manuals or schematics ? Thanks a lot , vlado
  • Posted 15 Aug 2012 06:14
  • By vavco
  • joined 3 Feb'08 - 15 messages
  • Sabinov, Slovakia
e-mail: vladovavrek@gmail.com
HI Mate
Sounds like a thyristor has gone faulty on the P500 pump controller, most likely short circuit hence once it triggers it cannot shut off.
You should be able to identify the faulty thyristor by testing continuity with a Digital Multi meter, also check your thyristor gate readings if you cannot find the short.
  • Posted 16 Aug 2012 23:18
  • By elektrodrive
enquiries@elektrodrive.co.uk
hello vavco; we had that same problem also, we had to replace the controller (SV662/13078) but I do recomment to control the diode and thyristors before changing the controller.
kind regards
marcb
  • Posted 16 Aug 2012 18:03
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Deborah Baker Deborah Baker
Ncn 110TH
Ncn 110TH 2015
Taylor TX175
New - Sale & Hire
RAEDER-VOGEL
