Komatsu FB 15M intermittent drive problem help pls
Using my komatsu FB15M today.
A load (builders bag full of rubble) came loose and fell about a metre before the backup rope stopped it from falling to the ground. This jilted the machine. Since that moment I’ve lost drive forward and backward.. not completely though- I turn the machine on, select forward or backward (with lever beside steering wheel) I can hear the starter motor wizz up as normal (I think it’s a starter motor).. But when I put my foot on the excelortor there is no movement for about 4 seconds ish.. then the machine lerches forward at full speed.
I took the panel off to have a look at the twin motors and I can see the brakes etc..
when I press the accelerator I can see the motors trying to turn, maybe turning ever so slightly.. then suddenly woosh were going full speed.
Everything else works fine on the forklift, lifting up, down, side shift all ok...
I was using the forklift most of the morning without problems until this.
Any help much appreciated, I’m pretty stuck without it
Thanks, Rowan.
  • Posted 25 Nov 2018 07:48
  • By rowan_h
  • joined 25 Nov'18 - 1 message
  • United Kingdom
I believe it may now gone into limp ssfe mode you can put it on the computer with komatsu
program and clear fault
  • Posted 25 Jan 2020 21:31
  • By Firerescue
  • joined 25 Jan'20 - 9 messages
  • New Zealand
Bryan
Factory Cat MICROMAG20D
Kalmar DCE160-9
Kalmar DCE160-9
Linde Material Handling
Michel Denis Michel Denis
