knock knock knock. who there?
Forklift knocking replaced the plugs, wires, distributor cap, and rotor button. but its knocking pulled one plug at a time the knocking didnt start. Im thinking something mechanical a push rod. its a Mitsubishi motor.
Model#FGC15
Serial# AF81B-52287
  • Posted 14 Apr 2015 00:00
  • By craig_k
  • joined 2 Apr'15 - 10 messages
Does the noise change if trans put in gear? If the tilt cyl's are dead headed, does the noise change?
  • Posted 14 Apr 2015 10:22
  • By bbforks
Just had a DP35K in the shop same issue. Found the Flexplate and Torque Converters bad. Harmonics vibrate though the engine.
Also seen bad u-joints in shaft going to Hyd pump..
some things to check
  • Posted 14 Apr 2015 04:02
  • By Prentice
