Raymond 102T-F45L:
Keeps blowing key switch fuse
Its an intermittent problem. Could go three weeks or moving 12 pallets, its hard to say. You R&R the key switch fuse and unit works good till it blows it again. Thinking wire harness issue and batteries load test at 23.1volts.
  • Posted 17 Apr 2014 02:33
  • Discussion started by tomas_s
  • Bahamas, Bahamas, The
With quoting a wire harness along with some other stuff time and materials to repair this old unit was going to be about $1900. With a new one costing $3995 the customer is just going to buy a new one.
  • Posted 5 Nov 2014 05:04
  • Reply by tomas_s
i found on 2 seperate ocassions the power card n/g
  • Posted 31 Oct 2014 10:25
  • Reply by forkup
most problems i find with shorts on these is the harness under base of steer arm There are two ports that allow wires to be routed to side of drive motor. At the factory they ran the wires through one port. There is a service bulletin that says to split them up and use both ports.
  • Posted 20 May 2014 09:37
  • Reply by ross_g
Linda Häkkilä Linda Häkkilä
edition #1228 - 1 May 2025
Lift Technologies Inc.
Louisville, KY, United States
Dubuque, IA, United States
