kalmar transmissions
got a kalmar DCD 70-6 S.NO. T321031493.
Driver says it sluggish in first gear only when in auto?
picks up fine when just put in first gear.
I know theres settings in the dash but scared to adjust without info and not sure how adjust if adjustment is required.
Has anyone got any info or ideas?
  • Posted 27 Mar 2013 05:24
  • By bing098
  • joined 2 Mar'12 - 40 messages
  • Kent, United Kingdom
sirbing@hotmail.com
Got the access codes. Have set up the thottle before on other trucks when they have needed it and checked fault codes.Did try a few years ago to copy one set of transmission set ups from one truck to other once but seem to make it worst so just re-entered the same settings. Hoping someone might have the set up procedures to email me as i think it might need to be set up to that truck?
  • Posted 30 Mar 2013 06:31
  • By bing098
sirbing@hotmail.com
you will need an access code to get in the ecs (cant give it out sorry)
might help also to have the manual with you so you wont wack up the settings :)
but yes you can change the way it reacts when in auto shift mode
  • Posted 29 Mar 2013 11:21
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Your truck should have a display (ECS) and it will show the gear selected and the direction, 1F for 1st forward. In auto the gear lever is left in 3rd and it will start off in 1st or 2nd depending on how it is set-up and shift up as the travel speed increases. There maybe a setting you can change by scrolling through the display but I think you will need a code to get into the set-up menu's, this maybe available from Kalmar but I am not sure if they will give it out.
Steve.
  • Posted 29 Mar 2013 08:32
  • By steven_w
  • joined 20 Oct'06 - 16 messages
  • Aberdeenshire, United Kingdom
That sounds possible Steven how can i check this and set it up go go off in first?
Did look into the dash one day but wasn't sure how to adjust.
  • Posted 29 Mar 2013 05:48
  • By bing098
sirbing@hotmail.com
Are you sure it is moving off in 1st gear in auto?, it may be set up to start off in 2nd.
  • Posted 29 Mar 2013 04:10
  • By steven_w
To be honest i don't know AAPEE will look at next visit got some minor jobs to do on this truck. What you thinking?
  • Posted 28 Mar 2013 03:51
  • By bing098
sirbing@hotmail.com
does the truck have a controler right side of the driver behind a panel ( apc 200)?
  • Posted 27 Mar 2013 21:36
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SNORKEL A46JE
Hawker Powersource, Inc.
USD1
SNORKEL A46JE
