Just have a question about a hydraulic cylinder
It's off an electric Linde forklift. I bought a rebuild kit for the cylinder but am having a **** of a time getting the piston off. It has an internal Hex casted in the end of the piston no nut keeping the piston on. So how I see it is the piston is threaded into the rod. Is there a trick to un-threading this so I can replace the o-rings within and remove the head. I welded a nut in the end of a bolt and put the head of the bolt in the hex on the piston and was able to get a 3/4" impact on it but had no luck trying to back it out. Maybe heat?? Any information would be greatly appreciated.
Thanks
Kirk
Bregar machine and industrial maintenance
  • Posted 31 Mar 2020 00:38
  • By Kirk_Bregar
  • joined 31 Mar'20 - 3 messages
Kirk
Yes, you need to remove it and yes there is loctite on it. Best way is to heat it up then you can break the loctite and reseal.
  • Posted 5 Oct 2020 21:21
  • By Jt_Ng
  • joined 5 Oct'20 - 18 messages
  • Victoria, Australia
It's been a while since I've seen one but I don't recall having to remove the internal hex plug to repack the cylinder.
  • Posted 23 Apr 2020 22:33
  • By duodeluxe
  • United States
duodeluxe
ok it's the mast cylinder
let me ask you this
is it leaking oil around the top of the cylinder where the ram comes out?
or, is it drifting down when raised up?
IF it is just leaking oil out of the top then you may can get by just putting new seals in the cap where the ram comes out.
But IF it is drifting down then there might be 2 things causing that, 1-the packing on the ram OR 2-the safety valve could be defective, all cylinders on masts have one, usually they are located inside the base of the cylinder or in some cases they are part of the inlet fitting depending on the design. The purpose is to keep the cylinder from dropping too quickly if a hose were to burst. Some call these velocity fuses.
From the sounds of it you already have the cylinder apart so changing the seals on the ram still may need to be done but if they aren't damaged you may can get by with what you have if you can't get it apart. If push comes to shove and you have issues with it you can always take it to a hydraulic repair shop and they usually can do all this for you.
  • Posted 1 Apr 2020 06:44
Yes it's the mast cylinder I have a picture of the cylinder just don't know how to put it on here.... oh well thanks for the info!!!
Take care.
Kirk
  • Posted 1 Apr 2020 01:38
  • By Kirk_Bregar
Kirk
i have seen some made that way, that would explain the hex hole in the end of the piston.
I'm going to make an assumption that this cylinder is one of the mast cylinders? those are the ones that are usually configured this way, the tilt cylinders generally have nuts on the end of the rod/piston end in most cases.
  • Posted 1 Apr 2020 00:11
Thanks that's what I was thinking a loc-tote was probably used. I take it the piston has a male thread that is threaded in to the chrome rod
  • Posted 31 Mar 2020 23:36
  • By Kirk_Bregar
Kirk
without knowing the model lift or having any sort of idea of the cylinder type this is a difficult one to answer. The question is do you need to remove that piston assy off the rod or not?
Some seals were made in some of those pistons in a way where you had to stretch them over the piston assy, usually heating the seals up so they would be flexible enough to stretch so they would not break.
If this is a case where the piston has to be removed though a little heat might be required to soften the threadlocker/sealer used to keep it from coming loose. Just be careful in heating, if you put too much heat it could warp the rod and cause problems after reassembly.
Note: all this information is just an educated guess since we do not have any model number of the lift or which cylinder it is.
  • Posted 31 Mar 2020 22:44
Autolift E180AT36B-D5-180
Maxlion R2B25LI
MAXAM Tire, Inc.
