JUNGHEINRICH EFG316, SP GE115-300ZT, FN314947, 2004Year
Hello.
I have error 040.
Lights in the Lower hydraulic engine temperature warning light. The hydraulic functions are slowed down.
The original problem was that the mice had chewed the insulation of the water, and these have spilled from a few cables and a little burnt, blazing over the insulating tape. I think the wiring repaired, but the fault does not want to disappear. The drive motor and the hydraulic motor temperature sensor is equally 55-60 ohms. What I measured the two-motor series with the sensor. The hydraulic motor wheel sensor goes to the servo motor is connected to the connector and routed in series, but that is just a lot of 100kiloohms terminal resistances can be measured, not as a hydraulic motor, 55 to 60 ohms. This is the engine temperature sensor as well? The servo motor type ISKRA 16902306.
Should this terminal connection diagram and a mostly down wiring of temperature sensors, perhaps this type of machine. There is more but just like my drawing. Besides not working, not even light up on the auger speed control, but this is probably an older fault.
Best regards, Laci
  • Posted 19 Mar 2013 04:27
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Thanks Nemanja
Laci
  • Posted 19 Mar 2013 15:10
  • By LACI
  • Serbia
Hello Laci
Error 040 is traction motor temperature,check wiring if you check temp sensor on drive motor.You have my phone.King Regards
  • Posted 19 Mar 2013 06:29
  • By nemanja_k
  • serbia, Serbia
SMV (Konecranes) SL37-1200A
UN Forklift FBR25NQC3
