jungheinrich EFG-V-16 forklift with error code 28
Can someone tell me what the error code 28 means at a Jungheinrich forklift truck model EFG-V-16? So now en then the truck goes into this error and nothing works any more.
Can someone supply me with the drawings of the controller board. I have looked at the wiring of the truck. All looks good. I think some parts on the electronic controller board have some error so that there is so now en then no energie to switch on the FET's.
  • Posted 19 Sep 2009 01:24
  • Discussion started by Blom
  • ZH, Netherlands
try www dot tvh dot com
  • Posted 17 Oct 2009 22:51
  • Modified 17 Oct 2009 22:52 by poster
  • Reply by rogeliodjph
  • Saudi Arabia
Know where can I have to JUDITBOX of the Jungheinrich?
  • Posted 15 Oct 2009 21:35
  • Reply by AIAROS
  • Mafra, Portugal
Thanks Elektrodrive and Billy B for your answers.
I have now an idea where to look. Probably the inductor coil. It's a big heavy part on the PCB.
The forklift truck rides on e area with stelcon plates on the ground. I can expect that the connection wire is broken.
Can one of you supply me with electronic (pricipal) drawings of this controller board?
What price must I expect when I buy this controller board?
regards
Piet Blom
  • Posted 22 Sep 2009 16:12
  • Reply by Blom
  • ZH, Netherlands
Elektrodrive is correct. You should have a flashing code on the traction controller 4x. It means you have a fault in current sensor. Change the pcb according to the book :)
  • Posted 19 Sep 2009 04:55
  • Reply by Billy_B
  • Slovenia, Slovenia
Sorry I think that was for the ac version truck. The 28 code states that the current sensor is defective. I think the LED flashes 4 times on the card.
  • Posted 19 Sep 2009 02:09
  • Reply by elektrodrive
On the steer colon I only find a oil pressure switch. the steering is hydrolic.
  • Posted 19 Sep 2009 01:43
  • Reply by Blom
  • ZH, Netherlands
I think this relates to the steer pot error. Possibly a faulty steer pot or a broken wire in the loom. Perhaps someone can confirm that is the correct code info.
  • Posted 19 Sep 2009 01:35
edition #1229 - 8 May 2025
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
