JLG 660SJ error code
Hello,
I have an aerial work platform with the error code below, can anyone help me with this?
*(437) engine troublecode 171:12
Machine:
JLG, 660SJ, 0300152492
Engine:
Deutz, D2011L04, nr. 11133411 , enginecode C30I336D
  • Posted 21 Oct 2023 00:52
  • By Forklift123
  • joined 11 Feb'21 - 39 messages
  • Netherlands
Mechanic of Forklifts, Aerial platforms & telehandlers in the Netherlands
fault 171:12
control unit hardware fault
Internal temperature for control unit not in permissible range
does the fault clear when you shut down and restart?
the suggestion says to shut it down and restart it and it should start up normal but if problem reoccurs to call Deutz service.
It almost sounds like a faulty temp sensor or wiring.
Also check the fan belt and make sure it is not loose.
It doesn't specifically say but another possibility could be the engine controller is getting hot.
That's the trouble with the service literature, sometimes it isn't very specific.
  • Posted 22 Oct 2023 14:22
  • Modified 22 Oct 2023 14:25 by poster
Yikes!...sounds like broken or bad canbus wire from engine to control module
  • Posted 21 Oct 2023 02:36
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
RAEDER-VOGEL
edition #1281 - 14 May 2026
UN Forklift FBRP15NQZ2
Advance CS7000
Illinois, United States
USD8,000
