JLG 20 DVL Serie 0130007550
Hi. The joystick card has already been changed, but now the new fault code presented by the platform control module is 202, can you help me solve this problem?
  • Posted 12 Oct 2019 12:56
  • Discussion started by Carlos_L
Mejor Renta
JLG proceedures are as follows:
First:
try cycling the key on and off 5 times. On each key cycle wait 10 seconds before the next cycle. This should clear any faults.
When you replaced the joystick module did you calibrate it?
this has to be done before the unit will operate correctly.
Depending on the mfg date and serial number of the unit the calibration procedure is different, there are 2 different platform consoles is why.
early models have a diagnostic port on the platform console and you short pins 2 and 3 and turn unit on to calibrate the joystick.
Later models with the newer joystick console have to be done through the diagnostic interface with handset or ground control access.
  • Posted 14 Oct 2019 06:43
  • Reply by swoop223
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
Toyota 8FBE20U
