intermittent throttle
Hello everyone. I have a toyota 7fgcu30 serial 69552 on lpg with throttle cable not ecs setup. I am having problems with the throttle randomly cutting out. It will run fine one minute then it will loose throttle response. even with the pedal fully depressed it only idles. Recently it has gotten a new propane regulator, filters and a full tune up. It runs fine just no acceleration from time to time. Any help or pointers would be greatly appreciated.
  • Posted 13 Mar 2015 07:00
  • By shaner
  • joined 1 Mar'11 - 29 messages
  • British Columbia, Canada
the screws that hold the plate to the shaft in the governor were loose causing the plate to flutter. Thanks for the pointers
  • Posted 14 Mar 2015 05:30
  • By shaner
The governor that's mounted under the carb has it's own throttle plate and that may have a problem.
  • Posted 13 Mar 2015 07:11
check out the governor
  • By stam
Airman ENCL045
Crown CG33P5
