Intermittent Slowdown When Lowering The Mast
The forklift sometimes takes for ever to lower the forks.
All other functions on the forklift work great.
The Mast is a Toyota 3-Stage FSV 189" W/Sideshift
We checked the all the mast bearings & found them to be ok along with the shimming of the rollers & again all is ok.
Goes up good everytime, goes down slowly even when weight is on the forks. The primary Freelift cylinder was just overhauled.
Truck is a 48V Electric powered ride-on. Thanks, Paul
  • Posted 18 Feb 2012 01:02
  • By Ogie
  • joined 27 Oct'10 - 9 messages
Ogie's LIft Truck Ltd.
Thanks All Our Customers & Suppliers.
There is meant to be a special tool for removing / fitting one type of the hose rupture valves, we tried to get hold of it the other year for a safety campaign on a BT but no such luck.
The valve had 6 holes on the face, stuck 2 x 4mm allen keys in opposite holes on the valve face then used a adjustable spanner on the allen keys to unscrew the valve.
The other type of valve was a normal internal allen key / hex fitting.
  • Posted 20 Feb 2012 00:59
  • By Forkingabout
  • england, United Kingdom
In the bottom of the cylinder, behind the fitting the hose goes to, is a piston and spring "fuse". Check to see if debris is stuck in there or a spring problem.
  • Posted 18 Feb 2012 07:29
Lift Tek Elecar
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
Kelly Stewart Kelly Stewart
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
at-large director, AED
COO, Intelligrated, Trew and Transnorm
