Hyster H50XM:
intermittent charging issue
hello all, I have a Hyster H50XM, s/n: H177B56725C that makes me want to set fire to it. Here's the skinny: it starts & runs just fine, but while it's running, the charge rate will occasionally drop off to 12 volts. It will come up to 14.2 if you floor the accelerator, but it will eventually drop back. I have an operator on this beast who is inattentive at best, so he keeps running it, oblivious to the charge indicator in the dash which results in an undercharged battery, jumpstarts, etc. So far I have replaced the alternator, had the new one bench tested, new battery, checked & cleaned all the engine & chassis grounds, checked every part of the wire harness I could get to for corroded pins or worn insulation, checked for voltage drops and high resistance throughout the charging system. I'm at my wits end here, and any pointers would be greatly appreciated.
  • Posted 20 Feb 2015 07:42
  • Discussion started by WrenchMonkey
  • Washington, United States
"uh... it broke."
went back at this yesterday, & crawled over the wire harness with a fine toothed comb. I found a single wire running down to a sensor on the bottom of the tranny that had slightly worn through between the tranny & the chassis. Repaired the wire, and all is right with the world. Thanks to all of you for your suggestions!
  • Posted 21 Feb 2015 00:32
  • Reply by WrenchMonkey
"uh... it broke."
you may need to add a ground cable from the frame to the motor, you can add a jumper to see if that works for you.
  • Posted 20 Feb 2015 22:12
  • Reply by edward_t
may have the wrong pulley on the alternator. just a thought.
  • Posted 20 Feb 2015 09:44
  • Reply by stam
The belt is brand new, and I can't turn the alternator without trying drag the crank along for the ride, so grip on the pulley is good. I hadn't thought to check that, though, so thanks!
  • Posted 20 Feb 2015 08:12
"uh... it broke."
Could the fan belt be slipping? Maybe try putting a wrench on the alternator pulley nut and see if the belt has good grip in the pulley.
  • Posted 20 Feb 2015 08:00
  • Reply by mrfixit
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
