instrument dash not working properly
I have this lift serial sq50nsybq and the lift wouldn't move but hydraulics would. Local shop supposedly fixed. When it came back it would move but dash would show red light on battery level (even though it was full charge) and no lights on fast/slow button area and hour meter always stays on(even when you turn off switch). They say it's a bad battery. Switched out battery, same issue. Replaced card from junk yard as they don't make original card anymore. Same issue with instrument dash. Any help would be great
  • Posted 25 May 2023 00:26
  • By loral_kinney
  • joined 25 May'23 - 1 message
Loyal,
Serial number is not correct. Should read as letter, 3 numbers then another letter followed by 5 numbers and last one is a letter. I would suspect the controller may not be programmed correctly or wire connected to the wrong terminal. Good Luck
  • Posted 31 May 2023 04:29
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
