Injection Pump Solenoid
I have either a P5000 or DP25K in my shop right now and I'm not getting any power to the solenoid at the injection pump. I have traced wires all the way back to the fuse and relay box. I found some corroded wires for the battery to those two blocks i repaired and replaced them and one of the wires that needs to get power isn't getting power. It's as if it has a bad relay but the relays are good. I was able to use a jumper wire to the wire I need to have power and it started right up. I'm not sure why its not working when everything is plugged in. Any thoughts? Sorry for the novel.
  • Posted 8 Jul 2016 05:52
  • By CJ583Jeep
  • joined 8 Jul'16 - 1 message
need to know which one it is
P5000 is different than a DP25K
get the model and serial number off of the dataplate
  • Posted 8 Jul 2016 22:09
Enforcer FLBAXT25
Toyota 02-8FD25
