Hyster E60XM:
indecator lights, not running
I have a E60xm-33, F108V11341U
Just purchased used with dead battery, Supposedly running when parked. I installed new battery and im getting indicator lights on the dash and no motor running. The first light looks like a wheel turning, the second is a wrench over an open book.
When i turn on the ignition lights and dash come on. Reverse beeper will sound in reverse is engaged. When i turn off the ignition I hear a long loud beep. Parking break switch looks disconnected with no wires in the vicinity. Im assuming not all the safety switches are in the proper place to run. Your help is greatly appreciated!
  • Posted 13 Dec 2016 05:10
  • Discussion started by nic_l
  • Louisiana, United States
The park brake warning should not stop the truck from running. You can short the wiring to trick the truck into thinking the park brake is set.
  • Posted 20 Dec 2016 00:35
  • Reply by BREWSKI
Where are you checking the voltage? -15 is not a startup problem. Check the voltage at the controller cables. Also check the voltage at the control wire inputs to the controller.
  • Posted 20 Dec 2016 00:33
  • Reply by BREWSKI
I have correct voltage at this point. What is the starting operation? I can't get the unit to move or lift at all. The contractors are not operating. It it possible I'm not following the starting routeen?
  • Posted 19 Dec 2016 02:20
  • Reply by nic_l
Voltage is good. Machine is listed at 36V and has 36+V. When i turn off the ignition there is a long beep. Our other machine does that when the parking brake is not on. THis machines parking break sensor looks to be disconnected and im not sure where they went. any other ideas?
  • Posted 14 Dec 2016 01:37
  • Reply by nic_l
-15 is a battery voltage low code. Check the batter total voltage. For 36 volt it should be above 35.1 volts, for 48 volt it should be above 46.8.
  • Posted 13 Dec 2016 09:24
  • Reply by BREWSKI
yes it does. I dont know how to post pics on here so i made the dash my profile pic. Two indicators light up and a -15 is displayed.
  • Posted 13 Dec 2016 06:37
  • Reply by nic_l
Does the dash have a LED display?
  • Posted 13 Dec 2016 05:47
  • Reply by BREWSKI
Toyota 02-8FD25
Taylor TT300
USD98,500
edition #1228 - 1 May 2025
Dubuque, IA, United States
Louisville, KY, United States
