IMPCO Model J diagnostic
This little forklift has a problem keeping its rpms up during a load. It will start and idle just fine, but when it climbs up the apron, it bogs down like it is flooded. I can put it in neutral and rev it up to get it to smooth out, and then try again. I've adjusted the carb in the normal way, but it does little good.
I'm suspecting the fuel delivery system, starting with the IMPCO converter. When I push on the little primer button while engine is running, there is no difference in engine speed.
On this converter, the atmospheric vent balance port has a tubing fitting, but no tubing to anything. If I put my finger over the vent balance opening, the motor dies.
Thanks for any insight.
  • Posted 16 Nov 2011 05:23
  • By Rigormortis
  • joined 16 Nov'11 - 1 message
  • Alaska, United States
Bunch of repair tips here: https://intellaparts.com/p/068jb/hyster-nissan-toyota-yale-impco-model-j-regulator-068jb.html
Also check out here shows what's included in repair kit https://intellaparts.com/p/068rkj/hyster-clark-impco-repair-kit-model-j-068rkj.html
  • Posted 25 Jun 2024 04:33
  • By M_VANDENTOP
  • joined 8 Sep'08 - 51 messages
  • Michigan, United States
intellaparts.com
some things not yet mentioned, but worth considering in my not all that humble opinion...
You mention "when it climbs up the apron, it bogs down like it is flooded" does it also bog under lifting a load, or only in gear (bad torque converter/ cracked stator if related to under traction/drive load, and not under any other loading).
also it is normal if the diaphragm can not move (like when you cover the vent/atmospheric side of the regulator) for the unit to die off, since the diaphragm needs to be able to flex to allow gas flow.
also, if this is the Peugeot engine, the way they are built often causes moisture to build up in the holes for the spark plugs, causing intermittent rough running, particularly if the truck gets washed.
  • Posted 9 Feb 2012 21:20
I think this is a Daewoo truck with a Puegot engine. They were real turkeys on power to start with. If you can push the button all the way in with no change, replace the converter. They are $100 here in the lower 48. Converters generally only last 5 to 8 years. If you are short on cash and have time to burn, they are easy to rebuild. I think a rebuild kit is only about $30. Nobody rebuilds because a complete new one is is cheap as paying me the labor and parts to rebuild one.
  • Posted 9 Feb 2012 14:26
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Rigormortis;
The vent line on the Impco goes to the air induction system after the filter. It is controlling the response time of the fuel delivery. Perform the manometer test of the fuel delivery system between regulator and carb to see how many inches of vacuumn is there. It sounds like you might look at the governor or electrical systems first.
  • Posted 16 Nov 2011 13:49
  • By MEngr
  • Missouri, United States
Pushing the button should make it run very rich and stall. Sounds like the convertor is not being supplied with enough fuel due to a pluged filter or something wrong with the hose from the tank.
  • Posted 16 Nov 2011 13:20
UN Forklift FBT20NQZ1
SMV (Konecranes) 4632CC5
Tapio Rummukainen Tapio Rummukainen
President, Logisnext Europe
Chief operating officer, Clark Material Handling Company
Lithium battery sales manager, BSL Battery
Chief executive officer, Corvus Robotics
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
