Unicarriers (& Nissan) CPH02A25PV:
Idles somewhat rought
92047 is the serial number. Has an H20 motor.
This unit will idle ok, not quite what it should. When you hit the throttle, it opens up to about 1700 RPMS, and quickly falls back down to 0, cuts the lift off. While running, and when I go to hit the throttle, I spray a aerosol lubricant around the intake gasket mounting and the engine will maintain 1700 RPMS as long as there is a spray. I am going to install an intake gasket. Has anyone else run across this?
  • Posted 26 Jan 2016 17:12
  • Discussion started by Hero5
Take care of the customer
Well I found the problem. After going through the engine vacuum system, it ended up being a restricted muffler
  • Posted 29 Jan 2016 12:01
  • Reply by Hero5
worn out govenor
  • Posted 27 Jan 2016 14:13
  • Reply by fixnproblems
seems common check the manifold for cracks as well
  • Posted 26 Jan 2016 21:58
  • Reply by Adams1
  • Indiana, United States
edition #1234 - 12 June 2025
