Hyundai Support
Folks,
I've noticed there are a lot of unanswered questions in the Hyundai section.
Even though there are few, I just wanted to let you all know I will start checking this section regularly to try and correct this.
  • Posted 17 Feb 2015 11:44
  • By Robe
  • joined 6 Mar'13 - 105 messages
  • Nova Scotia, Canada
Showing items 1 - 20 of 37 results.
Hey robe, I have a Hyundai 30l-7m. It is a no start condition. Has a lot of fuel pressure leaving the regulator going to the epr. I just replaced the regulator but that didn't fix the issue.
I pulled codes and there is many codes. 6420, 1173, 1644, 2123, 1626, 6530, 1611. Not sure if you have a fault code list or any ideas why I'm getting high fuel pressure. Thanks
Any help would be appreciated. Thanks!
  • Posted 4 Mar 2025 05:07
  • By Michael_Brown
  • joined 17 Jan'25 - 14 messages
can you help with a hyundia 25L-7a 2013 year? how do you get codes from cel chasing random no start issues an a dead pedal issues or not full pedal
  • Posted 26 Mar 2024 07:49
  • By James_Head
  • joined 24 Mar'24 - 3 messages
  • Missouri, United States
learning
any luck on info how to gets codes off this model with no laptop scanner?
  • Posted 24 Mar 2024 13:11
  • By James_Head
learning
  • Posted 24 Mar 2024 11:49
  • By James_Head
learning
Thanks Andrew. I already replaced 3 transistors in the ECM to correct a no spark issue. It runs great but randomly stalls for no apparent reason. A real head scratcher.
  • Posted 1 Jun 2021 05:41
  • By Alan_Darmon
  • joined 2 Apr'21 - 4 messages
Alan
You need the correct software and lead to get the codes. There prone for backfires there a pita. I had one last week, the cam sensor wires were broken at the plug. They looked good but came off with a firm pull. All 3 were broken. Also check the plug gap, too much gap causes backfiring but shouldn't put the eml light on.
  • Posted 1 Jun 2021 04:30
  • Modified 1 Jun 2021 06:05 by poster
  • By andrew_k
  • joined 17 Mar'07 - 363 messages
  • England, United Kingdom
I have a 30L-7A that backfires and stalls intermittently. It sets a check engine light. How do I get the fault codes?
Thanks
  • Posted 31 May 2021 09:41
  • By Alan_Darmon
Alan
I have a lpg hyundia which I bought off a broker who bought the lift from a forklift company. The lift gets no spark. I bought the manual on line and it was missing the trouble shooting section (the only part i needed. Does any one have 7-17 page for a hyundai 2008 25LC-7 / HC0210213
  • Posted 26 Aug 2020 04:36
  • By Gator
  • joined 3 Oct'14 - 45 messages
Hi,
I'm having issues with a Hyundai 13BOP-7 order picker. It's coming up with multiple error codes T82 encoder, T224 waiting for node, P 222 waiting for node.
I have a feeling the traction motor encoder or wiring might be playing up. Sometimes when you drive it will stop and code, sometimes it will drive very slowly and shudder, sometimes it will drive fine.
Any info on how to test encoder or diagnose fault would be appreciated. Thanks
  • Posted 13 Dec 2019 14:29
  • By Jofork
  • joined 4 Jan'17 - 23 messages
110d-7e keeps turning off. No idea what it could be
  • Posted 13 Oct 2019 10:04
  • By Josh_Lara
  • joined 13 Oct'19 - 1 message
Hi there,
i have a Hyundai flf25-5 and i am getting no spark, does anyone have a schematic for the electrical system in relation to spark control?? any help would be great, there is very little info on the interwebs!
  • Posted 29 Aug 2019 01:45
  • By AndrewP
  • joined 21 Jun'14 - 3 messages
  • Alberta, Canada
SELL THE BEST, SERVICE THE REST!
I have a Hyundai orderpicker (13bop-7) that throws a "p236 current gain" code. it's symptom is no power to drive and no lowering (lifts fine).
as this was a "p" code, I assumed it was in the pump controller, which I sent to FSIP. their message on return was that they expect the code to be in the pump controller.
any suggestions would be more than welcome.
  • Posted 3 Apr 2019 07:33
I have a Hyundai
70D-9
HHKHFA03PF0000035
flash codes
3714
3712
4677
4572
3868
Poor throttle response all fluids are good we do not have a laptop to scan etc, any direction would be appreciated.
Thanks Paul
  • Posted 4 Oct 2018 01:34
  • By PR2005
  • joined 18 Mar'06 - 23 messages
  • Illinois, United States
I was wondering if there is a way to get into a 25L-7a, heard you can probe two wires in connection for laptop to get codes to appear on dash. Done correctly ok, not correct burn ECU. Do u have pics of procedure to illustrate how too.
  • Posted 15 Sep 2018 22:14
  • By ducaticj
  • joined 15 Sep'18 - 2 messages
  • Idaho, United States
I'll see what I can do, check your mail and confirm you've received a message
  • Posted 1 Jul 2018 03:27
  • By Robe
The lift trucks its modelo HBF15T only, its the truck DC , the HBF15T-5 or - 3 are AC.
Please you help
  • Posted 1 Jul 2018 03:07
  • By Charly61
  • joined 29 Dec'15 - 56 messages
  • GUAYAS, Ecuador
there is no problem that has no solution.carlosgomezballadares@hotmail.com
HBF15T-3 or HBF15T-5 ?
  • Posted 17 Jun 2018 21:17
  • By Robe
I have a Hyundai L30-7a Forklift that was running just fine and we ran the hydraulics against which cut off the engine. We went to start it up and it would start and revs out like if the gas peddle would be held to the floor, and then its cut off by the computer. Can any one tell me whats going on??? Forklift guys don't seemingly know whats going on.!! Please help
  • Posted 17 Jun 2018 12:27
  • By joebloe
  • joined 17 Jun'18 - 1 message
Hello friend, if you could help me with information of the Hyundai HBF 15T, here is no technical information, this or the and could get anywhere. I need the electrical diagram. regards
  • Posted 8 Jun 2018 05:34
  • By Charly61
  • GUAYAS, Ecuador
Hello Robe,
I'm currently diagnosing a 25LC-7A that has a noticeable misfire but only at idle. Check engine light is on but I am unsure of how to check the codes.
There was a hose leaking on the mixer, that has been replaced. Also the spark plugs have been changed, all coils seem to be in good working condition. Misfire goes away during any off idle rpm including a manually held rpm.
Thank you
  • Posted 17 May 2018 22:42
  • By liftrepair
  • joined 23 Feb'17 - 4 messages
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
UN Forklift FGL35T
Taylor TX175
New - Sale & Hire
Alogotransiphobia is the fear of being caught on public transport without a book to read.
UN Forklift FGL35T
Taylor TX175
New - Sale & Hire
