hyster s50xl ... removed bad starter and 1/2 qt hyd. oil came out of bell housing... what now?
The starter stopped working and hyd oil came outof bell housing when starter was removed. It has a gm 4 cyl motor. Oil caused starter to fail, but why is hyd oil in housing? Any help?
  • Posted 24 Sep 2010 07:01
  • By bing
  • joined 8 Mar'09 - 5 messages
  • Minnesota, United States
As far as I know that truck has a wet bell housing and requires a sealed starter. Some Clarks are also outfitted that way.
  • Posted 27 Sep 2010 21:31
  • By duodeluxe
  • United States
duodeluxe
hello: binq
verifies the location of the pump hyd. if you are connected to the zone box clutch. replacing the seal thereof, is sold repairing kit. it is one of the problems that give us the pumps. other links even see seals and other internal. see level of engine oil for oil hyd. (Rise of excessive engine oil) in these cases the exhaust smokes. These are the possible cases of presence of oil on the clutch zone.
leakage of oil into the engine, the pump is on the distribution and if so you have to see the seals on the crankshaft, by passing through the seal which is the flywheel
  • Posted 26 Sep 2010 02:11
  • Modified 26 Sep 2010 02:13 by poster
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
