Hyster S1.5S errors
Hi everyone, i have problems with one Hyster stacker and i cant "translate" the error codes because i dont have the service manual for it. Can someone help me with the "translation" please.
Hyster S1.5S-3368 /2008/ SN:C442X02227F
The error codes are:
EP65283
CO36864
Thank you in advance!
  • Posted 30 May 2013 18:11
  • By mhonotone
  • joined 8 Feb'13 - 11 messages
  • Sofia, Bulgaria
mhonotone at gmail dot com
Ahoj, ked zatocím madlo v urcitej polohe zatácania vyhodí spomínanú chybu, chyba v potenciometroch??
Please use English Language
Littoral Translation:
Hi, when I turn the handle in a certain turning position, it throws the mentioned error, an error in the potentiometers??
  • Posted 22 Jan 2025 16:51
  • Modified 22 Jan 2025 18:10 by administrator
  • By Vladimir_Bulla
  • joined 12 Oct'21 - 6 messages
  • Slovakia
VMZ SERVIS
Hy, could you please help me with operation manual for Hyster S1,2S-4168 serial C442x01593c-2005 ? Doesn`t move and it`s making a noise like horn.
Regards
  • Posted 28 May 2014 19:25
  • By consold_c
  • joined 20 Jan'10 - 29 messages
  • PRAHOVA, Romania
pracsis
Thank you very much Geroj! I appreciate your help!
  • Posted 1 Jun 2013 00:27
  • By mhonotone
  • Sofia, Bulgaria
CO36864
The controller detects
that the security line
of EPAS has a too low
value
1. Switch off the key switch and switch it on
after few seconds and check if the same
error code is repeated
2. Make sure that the EPAS security line
connections between the EPAS controller
and the Combi controller are tight and safe
3. Check for the continuity of the EPAS
security line
- replace the wiring
4. Check if the EPAS controller fuse is burnt
- replace the fuse
5. Internal failure in the EPAS steering
system
- replace the failed component in the
EPAS system
6. Internal failure of the controller
- replace the controller
  • Posted 31 May 2013 06:11
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Lee Rushton Lee Rushton
UN Forklift FBT20NQZ1
Nagano NUL120-6
December 03, 2025 - New Delhi, India
