Hyster J2.50 XM Hydraulic problem
This truck has transistorised drive with contactors and a contactor for hydraulics switched by a control card at valve block. My original problem was hydraulics running continuously.
Found that control card at valve was damaged and burnt on back of card. Fitted new card now I haven't got any hydraulics but if I put the old card back on they run continuously.
Any ideas
Regards
Kev
  • Posted 5 Jan 2013 05:27
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
Kevtwad check again your mail
Regards
  • Posted 6 Jan 2013 03:25
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
The serial No is A216A02718U.
Didn't see a jumper lead, unfortunately i've inherited this job from someone else so there might be one.
Have got voltage across my hydraulic coil but can't figure out where it gets its neg from.
Regards
Kev
  • Posted 6 Jan 2013 00:25
  • By kevtwad
IS there not a small plug with a jumper in it that you swap from old card to neww.what is serial number A216??
  • Posted 5 Jan 2013 22:43
  • By kevin_k
  • By kevin_k
Did you check the right position of switch plates on levers??
Check your mail
Regards
  • Posted 5 Jan 2013 10:08
  • By nacsand_n
  • Madrid, Spain
MAXAM Tire, Inc.
Deborah Baker Deborah Baker
