hyster h80xm engine surge
I have a h80xm with a vortec v6 that surges when the throttle is pressed more than 1/2 way. runs fine at less than 1/2 throttle. i have checked for vac leaks at the gov controls and found none. i suspect the gov assy is the culprit but would like some other input.
  • Posted 20 Apr 2010 22:17
  • By rfost1959
  • joined 20 Apr'10 - 8 messages
I have a similar issue but at any RPM
engine runs smooth when I disconnect the ECM plg from the distributor. Any ideas?
Thanks
Justin
  • Posted 23 Aug 2010 22:57
  • Modified 23 Aug 2010 22:57 by poster
  • By justinm
rfrost,does this forklift run on gas or propane? If propane, check main line from vaporizer to carbuearator. It will crack in places that are not easily seen. If it runs on gas,check fuel filter and throttle body injectors
  • Posted 22 Apr 2010 09:56
  • By mark_l
  • joined 12 Mar'10 - 19 messages
The serial # is E004V03795A
  • Posted 21 Apr 2010 22:22
  • By rfost1959
what is the serial number series or what emmission controls are on this unit?
  • Posted 21 Apr 2010 20:25
have you checked gas flow, you're not getting a gas restriction are you?, gas convertor not "oiled up" is it
  • Posted 21 Apr 2010 06:31
  • By Barney
  • joined 21 Jul'09 - 20 messages
  • South Australia, Australia
