HYSTER H50XM H177B48014B stalls after 10 seconds..... DO INEED THE SCANER TO RESET THE ECU
Hi i had a unit overheat because the belt broke off and the operator used it until it started blowing out antifreeze i replaced the belt but ever since then the unit stalls out i check the L.P. gas made sure i have 1.5 to 2.0 psi coming out of the regulator the ignition checks out ok I believe i need to reset the ecu any ideas on how to do it on this truck it does have a GM 3.0
  • Posted 11 Sep 2009 13:50
  • Discussion started by marc_a
  • Baja California, Mexico
Do you still need help with this
  • Posted 18 Sep 2009 11:07
  • Reply by Fortis
yes i do have good oil psi i also replaced the psi sending switch
thanks
  • Posted 11 Sep 2009 15:04
  • Reply by marc_a
Do you have oil pressure? If the operator smoked the bearings the system will shut the engine down if it doesnt get oil pressure.
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
edition #1229 - 8 May 2025
Hyster
Lift Tek Elecar
