AAPPE PROBLEM IS I DON'T GET ANY POSITIVE 24 VOLT OUT OF MODULE TO CARRIAGE ASSY
TRUCK ONLY HAS SIDE SHIFT ALL OTHER WIRES NOT USED
THANKS FOR THE INFO
the are not the same.it shoud be possble to change the input and output on another line there are 1 line not used
AAPEE THANKS
TOP PGM MODULE WORKS , I GET 1. TO 5. VOLTS FROM HYD
LIFT, TILT , S/S POT
BOTTOM MODULE , THINK IS DAMAGED HAS LED LIGHTS AND LIGHTS UP
BUT NO 24 VOLTS TO S/S CARRIAGE SOLENIODS
I'M NOT SURE HOW SYSTEM WORKS
IS THERE A WAY TO TEST BOTTOM MODULE.
ARE THE TWO MODULES THE SAME , THEY LOOK A LIKE
THANKS
STU
I/o card 1 outputline no signal ther ar 2 cards the bottum card this is plug and play
