Hyster H110 XL with GM 4.3 V6 & TBI fuel injection-flooding& running rich
I've been having a problem with a hyster H110xl. it has two problems which may be related, both with the gasoline only fuel system.
The first problem is that it chronically runs too rich, and some times floods if it doesn't start on the first attempt. While its running it frequently bogs down while trying to accelerate and once and a while even backfires through the TB. It also some-times puffs black smoke, there is a huge soot stain on the inside of the CW, so its been doing this for a while, I would guess. With the air horn removed I can actually see fuel pooling up on top of the butterflys while it idles. I'm not very experienced with TBI style injection, but it looks like way to much fuel coming from the injectors to me. According to the available records the only thing ever replaced in the fuel system was a throttle pos sensor a few months ago. The spark plugs were also just replaced due to fouling, and at the current rate it won't be long before they're fouled again.
What should I look for to solve this problem? Check fuel pressure? Faulty ETC or MAP sensor? Bad ignition module? Worn out injectors? Bad O2 sensor? Does it even have one? While its running there is no CEL.
The second problem is an intermittent failure of the butterflys to open when the throttle cable is pulled. There is some sort of spring-loaded mechanism that interacts between the throttle lever outside the TB, the throttle shaft and the electronic governor. I think that it could be related to the flooding problem because when I witnessed it sticking it was also one of the times that the fuel was pooling on top of the butterflies (while the engine was idling) when the engine was shut off it immediately returned to normal. Any knowledge of this problem out there? Thanks.
  • Posted 20 Jan 2011 13:39
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
This industry has a lot of ups and downs
Andy
Have you solved your problems?? I have the same trouble with the throttle and I would like to know how to fix it.
  • Posted 18 Sep 2014 07:15
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
hey, Andy, just to keep the "bump", some time in the next few days, why don't you give us a serial number series?
  • Posted 21 Jan 2011 11:06
bump; because new discussions fall of the radar very quickly in the mechanical trouble shooting forum.
  • Posted 21 Jan 2011 07:41
  • By fixitandy
Hitachi HX64B2
SMV (Konecranes) 4632CC5
Sue Tomic Sue Tomic
