Hyster B60Z A230 Code 11
Has no lift or direction.Says code 11 on the hour meter. Hooked up Curtis hand set and said motor sensor? Checked everything suspect the Curtis control box
  • Posted 21 May 2013 11:43
  • By erik_j
  • joined 11 Dec'12 - 19 messages
Condition
Handset is plugged into the traction motor controller. Key switch is in the ON position. Diagnostic menu is selected.
Truck Response
No Traction
Possible Causes and Test Procedures
1. Incorrect traction motor wiring.
Check wiring to traction motor.
Loose, worn, or frayed wires?
Motor wiring correctly installed?
2. Check for motor shorted to frame.
Disconnect leads from motor.
Resistance between frame and motor terminal should be 1 mega ohm or more.
3. Check for controller shorted to B−.
Disconnect motor leads from controller.
Resistance between motor terminals on controller and B− should be 1 mega ohm or more.
  • Posted 22 May 2013 03:52
  • By JimB
  • joined 12 Apr'13 - 30 messages
Deborah Baker Deborah Baker
UN Forklift FD15-18T
Ice 28INCH-AUTO-SCRUBBER
USD8,350
