Hydraulic problem
All hydraulic functions work fine except that it lowers much to slow, what controls the flow when lowering (where is the flow control valve located)?
With lowering too slow being the only problem, do you have any thoughts on whether it is the safety valve or the flow control valve?
  • Posted 14 Mar 2018 04:39
  • Modified 15 Mar 2018 00:07 by poster
  • By keith_e
  • joined 14 Mar'18 - 3 messages
Thanks for your time to respond. I will try the flow control valve first and if no change, then the safety valve.
  • Posted 17 Mar 2018 00:21
  • By keith_e
Flow control in the main valve is a guess.
  • Posted 16 Mar 2018 07:00
Any thoughts on which one is causing the slow lowering?
  • Posted 16 Mar 2018 04:53
  • By keith_e
The flow control valve is on the top of the control valve in line with the lift spool. It has a screw and lock nut sticking out. The safety valve, in case a hose ruptures, is at the bottom of the right side lift cylinder.
  • Posted 14 Mar 2018 21:58
Esie Cortez Esie Cortez
Oxford Ct, United States
Manitou M50-4
Terberg YT220
