Hydraulic making clicking sounds
I purchased a Hyster S50XL forklift and did bunch of maintenance. Lots of water in hydraulic fuild, changed many oil seals on cylinders changed steering motor cause it was steering one way fast and hard the other way. Changed every filter washed out the hydraulic tank and put new AW32 S Super oil in it.
When the forklift lifts hard like lifting the end of a container the hydraulic makes an unneeded amount of noise "it seems as the pump", " a check valve", or "also sounds like if pump had gear drive, would click splines". It still lifts well. Would like to do pre maintenance before something badly goes wrong.
  • Posted 9 Feb 2021 13:09
  • By Blacktop_KPR441
  • joined 9 Feb'21 - 2 messages
Hyster S50XL
Sounds like a Hyster S50XL with a Mazda engine?, the pump is driven off a chain and sprocket set up off the front of the engine, when the chain wears out it will start jumping teeth on the sprocket, giving the clicking noise you speak of, usually very noticeable at end of travel during tilt function,
  • Posted 25 Feb 2021 23:29
  • By steppednit
  • joined 18 Oct'13 - 50 messages
  • Tennessee, United States
If it was easy, everybody would do it.
I went to the forklift parts store and looked for the pump and it shows a shaft driven spline pump. H50XL I mentioned a S50XL which is not the right number for my truck. I am told the mechanic who did most the work with maintenance says he had the pump right to pcs and it looked new still yet so it can't be the splines. I guess will just wait it off and see what happens if anything ever happens.
  • Posted 12 Feb 2021 13:29
Hyster S50XL
if your hydraulic pump is in center of truck you may have a chain drive pump and it may be slipping ?
  • Posted 12 Feb 2021 02:51
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
UN Forklift FB25N1LZ1
Terberg RT223
