Hydraulic levers lock
Hello everyone
I'm facing the issue of all Hydraulic levers are locked no movement on the levers.
Please anyone give me a solution.
Thank you.
  • Posted 14 Feb 2024 00:30
  • By JeromManickam_
  • joined 14 Jan'24 - 4 messages
  • United Arab Emirates
Jerom@9629
Jerom,
The hydraulic lock is set until operator is sitting in the seat, key switch is turned on and possibly seat belt locked. Make sure there are no lights on dash. Should the hydraulics remain locked, need to check seat and seat belt switch are operating correctly. If everything you check is good, verify harness connections at the solenoids that mount to the hydraulic valve. Good Luck
  • Posted 20 Feb 2024 00:09
  • By Fishmech
  • Virginia, United States
Nagano NUL120-6
Toyota 3FD100
