Hydraulic hose fitting
Jungheinrich appears to use some kind of special hydraulic fitting (quick release) for the mast, what fitting is this? I can't seem to find one that exactly matches.
  • Posted 2 Mar 2023 01:24
  • By Joery
  • joined 1 Mar'23 - 2 messages
  • Netherlands
Jungheinrich uses flat-face hydraulic quick-release couplers on the mast. They're designed to prevent fluid loss and dirt ingress, so they don't match standard hose fittings (https://aerocomfittings.com/categories/hose-fittings). You'll need the OEM style or an ISO flat-face equivalent in the correct size, best to check with Jungheinrich or a supplier like Stucchi or Faster for the exact match.
  • Posted 25 Aug 2025 01:18
  • By Ionut_Marian
  • joined 20 May'20 - 3 messages
  • Quebec, Canada
These are made by Junghheinrich, most hydraulic shops do not sell these or ones remotely related to these. However some shops will cut the the press fitting off with angle grinder to reuse the quick-release. Press fittting part can be replaced with generic one. However mostly are these used for reach trucks, and there the original Jungheinrnich hoses are more elastic than generic hydraulic shop ones. Also originals come off the shelf shorter so for installation you need to pulll them quite hard to install.
  • Posted 3 Mar 2023 05:55
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Toyota 02-2TD20
Terberg YT220
Libiao Robotics
