Nichiyu (& Nyk) FBRMAW20-75BC-650MSF:
hydraulic fault
Hi All, Hope someone can help, our machine has come up with a fault, on the panel flashes "*OFF HYD.LEVER TO NEUTRAL", originally forklift tech thought it was the 2 speed switch not centering, for forks lifting, but it was not, have since changed all micro switches and still no change. I have also reset the history memory (rotary switch) but still no solution found. The forklift can go forwards and backwards, but no action by hydraulics motor. Do anyone have a possible solution? Have done basic check on wiring loom and there does not appear to be shorting out anywhere? Can we bypass to get hydraulic motor to operate on its own manual switch.
  • Posted 22 Feb 2017 18:14
  • Discussion started by Pumpsgone
  • South Australia, Australia
Thanks for your help
Unicarriers FD80-2
Toyota 02-8FD30
Your Focus
Jefferson, WI, United States
Johnston, IA, United States
St. Louis, MO, United States
