hundai 35L-7A
Hello colleagues
I have a prolem with starting the engine error occurred 337
weak signal crankshaft position / wyminiłem the sensor for further was the same problem so I replaced the camshaft position sensor and the engine still does not start but misses the inlet manifold
where to look for failures
compression pressure of 9 bar
greets krzysztof
  • Posted 27 Jan 2014 09:03
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
Evaporator clean and ok?
Also check carburetor and choke plate condition... e.g. it's a common problem on Toyota LPG forklifts
  • Posted 1 Feb 2014 10:17
  • Modified 1 Feb 2014 10:25 by poster
  • By DukeLander
  • joined 16 Jan'14 - 34 messages
  • Vojvodina, Serbia
Hi
How to check the valve EPR?
greets krzysztof
  • Posted 1 Feb 2014 00:57
  • By krzysztof_k
  • śląśk, Poland
Hello
I mentioned shaft position sensor and camshaft position sensor for a new belt.
I checked the sensor wiring is ok
I checked the engine timing is ok
I checked the installation of lpg is ok
computer tested on the site is ok
there are no errors on your PC
the engine starts for 2 seconds and goes out
or shoots in the intake manifold as if he switched the ignition
I miss the idea of ​​what might be causing damage
greets krzysztof's
  • Posted 31 Jan 2014 15:18
  • By krzysztof_k
  • śląśk, Poland
Hello, Check for a broken wire to the sensor. It is a common fault.
  • Posted 31 Jan 2014 05:59
  • By HyundaiChCH
  • joined 31 Jan'14 - 2 messages
  • New Zealand, New Zealand
In 9 bars of compression?
Is there a spark on spark plugs?
Try this:
Take out the spark plugs,inject few drops of motor oil in combustion space (to reduce piston rings clearance),turn back the spark plugs,make sure that fuel will be in compression chamber on few engine turns or better use start spray.
If engine starts,heat it to normal working temperature,stop it and try to start again.
If it starts normaly,stop it and let it to cool down.
If engine not starting after cooling down,problem is in compression...
  • Posted 27 Jan 2014 11:26
  • Modified 27 Jan 2014 11:52 by poster
  • By DukeLander
  • Vojvodina, Serbia
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Terberg YT223
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Tacoma, WA, United States
Toyota launches three new stackers Columbus, IN, United States
