How to reset service maintenance light
The maintenance wrench light came on for our Cat e5000. Does anyone know how to reset the light? Thanks.
  • Posted 17 Mar 2016 21:27
  • By oxford
  • joined 1 Mar'16 - 4 messages
Hi, the wrench was for scheduled maintenance. I did find the service manual and figured out how to turn it off with the DRS switch.
On a brighter note, while finding out how to reset the light I also found out how to set the power curves for speed and hydraulics on the lift. It was a real shame the operator was trying to rush me while it was down for PM's as now everything operates as slow as it can go. HeeHee.
  • Posted 25 Apr 2016 08:10
  • By oxford
you have to identify which system is causing the wrench light to come on, it will usually show another light for the system affected along with the wrench light.
once you identify this and determine what is causing the problem usually by a DTC code on the display THEN you can repair the problem and the lights will turn off.
  • Posted 25 Apr 2016 06:07
Esie Cortez Esie Cortez
Oxford Ct, United States
