How to read battery discharge indicator
Can someone explain how to read the battery discharge indicator, no mention of this in manual or service manual.
When I switch the key on, all four lamps light up, but after a few seconds, only the one on the bottom stays lit. Does this mean low charge?
  • Posted 31 Jul 2023 03:15
  • By dixster
  • joined 31 Jul'23 - 2 messages
richard
Thank you, that's what I thought. My pallet jack has 4 individual deep cycle batteries in series, are those voltage figures still appropriate?
  • Posted 3 Aug 2023 10:48
  • By dixster
richard
dixster,
The bdi should have all lights lit when fully charged, drop as the batteries are being used. If the BDI is not a full charge after being charged all night, need to check fluid level in batteries, all cable connections. When plugging in charger, test battery voltage to what the charging voltage is. Could have a failed charger or weak batteries. You should only charge when battery voltage drop to 24 volts. Fully charged the voltage reading should be 27 to 28 volts depending on the age. Good luck
  • Posted 1 Aug 2023 03:51
  • By Fishmech
  • Virginia, United States
Still GX10
Still GX10 2000
Poland
EUR950
Taylor TXB180S
edition #1285 - 11 June 2026
Still GX10
Still GX10 2000
Poland
EUR950
Taylor TXB180S
