Hot, message code
Hello!
After of quick check of the stacker, I detected that the traction and lift motors are excessively hot, and the smell of hot brush is present from the lift motor.
This problem is interesting because the temperature rises only when the stacker has been used for less than 1 hour, with light use.
* Basically, the Stacker is new, with only 250 dead man hours.
* Lift motor is DC
* Traction motor is AC
* Lithium battery with external charger
* Serial number start with 7044
I think that problem is related with an error in factory configuration or maybe the package installed is not compatibly.
I don't understand what is wrong...
Thanks a lot...
  • Posted 23 Feb 2025 02:56
  • Modified 28 Feb 2025 09:37 by poster
  • By Guillermo_NC1
  • joined 23 Feb'25 - 1 message
  • Mexico
Guillermo Nuñez
