help with fault code
I am not sure model of lift I am not at work but it is diesel and a 12000 pound lift and it's giving me a fault code of 2000-12 and won't start any advice on were to start looking or ideas is very much appreciated thank you in advance
  • Posted 12 Dec 2014 14:24
  • By knucklebuster85
  • joined 12 Dec'14 - 3 messages
  • Tennessee, United States
Knuckle buster
The code comes right back when cleared the wire got burnt that goes to the hydraulic cooling fan and it melted plug two would that be cause of the code coming up or did this short out the vcm and fry it
  • Posted 13 Dec 2014 10:08
Knuckle buster
2000-12 is a "can bus error", ?maybe introduced while disconnecting things (like the vcm, ecm or dash) while troubleshooting?, but could even be a bad VCM, or dash or ecm.
Can you clear the codes and see if it comes back?
  • Posted 13 Dec 2014 02:24
  • Modified 13 Dec 2014 02:26 by poster
I will have model and serial number for you in just a bit
  • Posted 13 Dec 2014 00:28
Knuckle buster
Full Model AND serial number would be helpful first......
  • Posted 12 Dec 2014 16:43
  • By kevin_t
