Help Q1 transistor keeps burning
Have easy r30tt serial num etd01-10926 first I thought it was just the transistor as soon It travel it got burnt so I replace the power card and put in a new transistor with diode and it travel about 30 feet and transistor burnt again I have tested the drive motor for short but tested good any idea on what is going on thanks in advance.
  • Posted 9 Oct 2012 03:31
  • By edgar_p
  • joined 9 Oct'12 - 3 messages
  • Arizona, United States
Thanks guys for the help truck has no Regen but did removed the heat sink and found the insulation damage had a hole in corner did test with meter and showed good no continuity to frame so will order insulation and post my results thanks
  • Posted 16 Oct 2012 01:53
  • By edgar_p
I had replaced the Q1 from aftermarket and it lasted about a month. You have to buy it from Raymond as the Q1 comes as an updated kit and instructions. That is my experience and I have not had any failures with the OEM replacement. Also make absolutely sure your drive motor is good.
  • Posted 16 Oct 2012 01:29
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
Yes the regen will blow the Q1. you can unhook its cables and drive the truck to test and eliminate that as the failure. you must remove the heat sink to verify it has no holes in the insulator as an ohmeter test wont show anything. check all motors for shorts to frame!!
  • Posted 15 Oct 2012 04:45
  • By EasiTek
Look at all the advice in troubleshooting section for code 23.
Q1 failing has many issues...
Do you have regen?
Yes stated you checked the motor, what about cables?
If the heat sink properly insulated.
  • Posted 9 Oct 2012 05:32
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Enforcer FLBAXT25
Maxlion R2D25
