Height interlock
My Yale MTC 13 48V loses traction after 1.5 MTR. How to disengage this interlock. Can someone help
  • Posted 29 Nov 2024 21:52
  • By pankaj_shetye
  • joined 15 Jun'20 - 4 messages
  • India
Pankaj shetye
liftcraft enterprises
Pankaj,
If the lift stops moving after traveling 6 to 7 feet, need to check charge level of battery, fluid level and specific gravity. If you are sure the battery is fully charged, connect meter to battery and operate the lift. See how far the voltage drops when traveling and operating hydraulics. If you suspect an interlock is causing the cut off, you will need a Yale tech to connect with program to reset interlock or turn it off. Good Luck.
  • Posted 4 Dec 2024 01:20
  • By Fishmech
  • Virginia, United States
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
