Hard steering on Cat GP25k
Hard steering ! engine pump ok psi o.k od time just get stiff and if you use the tilt or other functions the steering loosen up.Could this be a valve problem or hose connected in the wrong place? any suggestions
  • Posted 9 Sep 2011 04:50
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
Sounds like the steering valve on the bottom of the steering column needs replaced.....one other thing to check is to see if the Hydraulic steer cylinder has a bent rod
  • Posted 9 Sep 2011 05:28
  • By kevin_t
Terberg RT223
SMV (Konecranes) 16-1200C
Kai von Berg Kai von Berg
