Hard Starting when Cold
Operators reported difficult starting first thing in the morning. Takes awhile then when it starts it runs OK during the day. Idle surges a little. Mazda FE engine
  • Posted 8 Mar 2024 12:31
  • By William_Kaono
  • joined 8 Mar'24 - 3 messages
  • Hawaii, United States
Thanks. I'll give it look.
  • Posted 9 Mar 2024 12:40
  • By William_Kaono
This truck on the later trucks were getting into emissions the lpg system had a Asian lpg converter after a while the converter would gum up and when cold would stall or hard to start you probably need to replace it or rebuild it.as for the surge there is a step up value on the side of the carb that steps up the idel when you lift a load or turn the steering wheel to help so the motor does not stall out might need to adjust it hope l was of help.
  • Posted 9 Mar 2024 12:36
  • By Scott_
  • joined 16 May'21 - 308 messages
Scott
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
