Hard Starting(running lean)
Ser#H177B50961B
2L Mazda engine
LP low emission Aisan open loop system
Engine will not start unless assisted with a squirt of cleaner or partly cover the carb intake to richen the mixture. Recently replaced the LPG regulator, tune-up and cleaned the carb ( did not remove and dissemble).
Seems to be more predominate when cold. I'm not to familiar with this system but what controls cold start-ups, appears to be some kind of injector on the side of the carb (mixer).
Any help would be greatly appreciated
  • Posted 29 Aug 2017 21:50
  • Modified 29 Aug 2017 21:52 by poster
  • By BrewCrew
We`re here for a good time
My customers contacted their fuel supplier, they said 100% of the repairs would be covered. We have new systems that require rebuilds and found dry hoses plugged solid with this waxy deposit
  • Posted 5 Sep 2017 23:43
  • By BrewCrew
Funny you should say that, we have had a run of problems with contaminated LP. We are seeing continual failure of regulator diaphragms. Some only lasting 50 hours. Trying to get info from the fuel suppliers is like pulling hens teeth.
  • Posted 5 Sep 2017 23:37
  • By BREWSKI
We have had many issues with LPG systems recently, I been told that some of the propane has been contaminated. This sheds a lot of light on recent problems
I'll let you know what I find regarding the injector
Thx again for the info
  • Posted 5 Sep 2017 23:12
  • By BrewCrew
I have had the carb cause this problem. The trim injector is usually the problem.
  • Posted 30 Aug 2017 07:23
  • By BREWSKI
I assumed it was a open loop since it has a resonator, I did not see one on a closed loop, but yes I removed and cleaned the injector. The first month it made a difference or maybe coincendental, guess I should replace it now
Any other checks I should do?
  • Posted 30 Aug 2017 00:26
  • By BrewCrew
This serial number is for a closed loop truck. Are you sure it is open loop? If it is a closed loop engine, clean or replace the trim injector that mounts at the base of the carb.
  • Posted 29 Aug 2017 22:27
  • Modified 29 Aug 2017 22:28 by poster
  • By BREWSKI
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Nagano NUL120-6
Elwell-Parker ESI500-36
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Nagano NUL120-6
