H1 Code
Hello everyone,
I have a Toyota 8HBW23, one of three units recently received. On this particular unit, if you switch directions quickly, it honks, throws a red H1 code, and continues switching directions.
The other two units are not exhibiting this behavior.
Has anyone experienced this issue before or know what the H1 code indicates and where I should start looking?
Any insight would be greatly appreciated.
  • Posted 16 Oct 2025 10:02
  • By RPugh
  • joined 16 Oct'25 - 2 messages
  • Arizona, United States
I'm going to follow up on this. It ended up being a bad battery in the pack. Our company had ordered 40 of these lifts to be distributed across 10 states to different facilities. Toyota had aggressively ordered sealed batteries from EnerSys to put in our units and they sat for way too long before being received by us. Toyota was proactive instead of reactive and had the batteries replaced on all 40 units on their dime. I had 3 of these units at my site. The battery replacement fixed this unit. I was a little surprised as the unit only had 10 hours on it. Toyota came out and determined the bad battery under warranty and expedited getting EnerSys out to get it remedied.
  • Posted 14 Nov 2025 04:54
  • By RPugh
H1 I'm sure is lift switch /pot can't explain why it is doing the rest
  • Posted 14 Nov 2025 03:45
  • By mobbsy
  • joined 30 Apr'13 - 25 messages
  • Cleveland, United Kingdom
thanks imobbs
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Hangzhou Maxlion Forklift Imp & Exp Co., Ltd.
UN Forklift FB25N1LZ1
SMV (Konecranes) 12-1200B
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
