Going forward
I am having trouble with forward, it will go once it engages the high
speed contactor ( im not sure if that is the correct term) but it does
not want to go in slow speed forward. It works perfectly in reverse.
any ideas? Sorry I am new to working on forklifts I bought this one to
use in my warehouse, I am an electrical contractor so I do understand
how to read a schematic just hope to get some input to point me in
the right direction.
  • Posted 18 Nov 2016 03:58
  • By josh_r
  • joined 18 Nov'16 - 2 messages
  • Missouri, United States
You will get out of life what you put into it....
It sounds like you have cables shorted or open. Other than common source connections there should be no contact between the pump motor and the drive motors.
  • Posted 22 Nov 2016 05:56
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
I will check on the drive motor next thank you for the suggestion. I dont know if this would give any more clues but I have figured out that if I engage the lift so the hydraulic pump is running it will drive forward normally at slow speed, if I release the control so the pump turns off it will stop moving forward...? It always works fine in reverse though...
  • Posted 22 Nov 2016 02:09
  • By josh_r
You may have checked already, but, confirm first that your battery is watered, clean and fully charged. (negative voltage can occur due to battery corrosion causing the controller to behave erratically).
Next, inspect cabling,wiring contacts and power bars for any obvious damage or opens. Then inspect drive motor condition (be sure to elevate drive wheels from floor to avoid sudden truck movement), check if possible drive motor brushes. Commutator should be dark coppery color with no burn marks or roughness.
  • Posted 22 Nov 2016 01:53
  • By tom_p
  • Alberta, Canada
Check all the contact tips. Really odd that it has this problem in one direction.
  • Posted 18 Nov 2016 04:22
  • By BREWSKI
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
Unicarriers FD80-2
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
Unicarriers FD80-2
Wellwit WMF1000
USD50,000
Bolzoni SpA (Group HQ)
Alogotransiphobia is the fear of being caught on public transport without a book to read.
