GM 3.0 liter LPG starts and runs good for 5 minutes, then loses power
Serial C187V13827S
This is a strange problem to understand.
Have been working on electrics for the past 6 years, so learning Internal Cumbustion again.
After 5 minutes of run time, engine won't rev up when the gas pedal is down to the floorplate.
It starts fine and idles good.
I adjusted the Air-Fuel mixture the way that is described in the Maintenance Section, Power Mixture adjustment did not make a difference.
Removed cover from the Vaporizer, very little tar build up and the components look good too.
  • Posted 20 Aug 2022 22:31
  • Modified 20 Aug 2022 23:37 by poster
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
It is strange that it takes 5minutes to show up daes it brake up or chock out when it starts to happen when you go to the floor with gas petal.also on the distributor is there two connection that are plugged in or one with two wires if there are two one with two wires and one with four wires at the front of the distributor disconnect the one with four wires and see if the problem goes away if so you could have a problem with the est in the computer or the Inigion module also by disconnecting you are by passing the governor because it looks for a tack signal to the controller under the dash to control the vacuum to the governor if you still have a problem get back to me and we will look into it more good luck.
  • Posted 26 Aug 2022 08:09
  • By Scott_
  • joined 16 May'21 - 338 messages
Scott
Combilift Ltd
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
Crown names top North American dealers New Bremen, OH, United States
Combilift Ltd
