gear movment
The forklift is not moving forward but backward is Okay. it we enter normal by it safe and also is showing error code P-22 , I have change the oil and also clean the filter please help
  • Posted 27 Aug 2021 21:53
  • By Kingsley_Chima
  • joined 27 Oct'19 - 19 messages
  • Nigeria
Onyems Kasco engineeing services
DTC P22 or P-22; Shift Lever Error Signal.
This DTC can mean that no shift lever input signal was detected for 2 seconds of time after the shift was made. This code can also set if duplicated shift lever inputs are detected by rapid shifting of the lever (creates a phantom code through hysteresis).
This code can also be generated when the Presence Detection System (PDS) is activated with the seat switch open.
Operate the truck while switching directions ( normal switching ). If the code returns then inspect for actual 'on' and 'off' activation of the transmission (T/M) shift solenoids. View them from the VCM input monitor page. View the operation of the directional lever while switching directions. Now view the transmission directional solenoid current (mA) during directional switching. There should be12 VDC applied and then removed from the solenoids.
Now, switch to the output monitor page. View the transmission (T/M) signal (neutral position) and then T/M solenoid "F" and then "R" while switching. If these are receiving input and output signals, then the system is working.
If one direction does not receive an input signal, check the wiring between the directional switch and the appropriate transmission shift solenoid. If there is a issue on the reverse side, you must also check the wiring from the reverse shift solenoid to the directional control and also to the backup alarm relay, fuse, wiring, etc.
This should help. I have also read about the meter panels also potentially causing problems.
  • Posted 28 Aug 2021 09:11
  • By BLey
  • joined 31 Jul'20 - 60 messages
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
November 3-4 2026 - Houston, United States
